installed my ev2 fuel pressure gauge today and have to say the install is very nice compared to the 3 ev1 gauges im running as well..
besides that after my 20 mile drive home i like the way the ev1 gauges work much better..does anyone elses ev2 gauges bounce around alittle? idling the needle bounces between 63-65 psi and cruising pretty much the same unless i hot dog it alittle where it drops down to 55-60 psi..just doesnt seem to operate as smooth as my ev1 gauges..
other things i noticed are it doesnt drop back to 0 with the truck off, it stays at whatever it was at right before i shut it off..green backlight is much brighter than the ev1's which i knew before i bought it..also it doesnt work with the headlight switch like the other ones, ignition has to be on first for the backlight to come on which doesnt really matter i guess its just nice to have them all work the same...
I just finished installing ISSPRO gauges in Tripple A-Pillar pod, Tran, EGT and Boost. Never had the EV1 so cant compare that but mine dont bounce but rather seems to rise incremental like a second hand on a close only when it rises a small amount. if it rises rather quickly to a larger degree it will rise smoothly.
and same here about when the truck is shut off they stay at their current readings, when i turn the key on they will go to zero then go right back to whatever the readings are on a warm start.
havent driven at night with mine yet, just finished installinng a couple hours ago so i havent seen the backlight yet....... but i will shortly
liking them so far
