need help installing isspro EV2 fuel pressure gauge - Ford Powerstroke Diesel Forum
Old 04-22-2012, 12:22 PM
ok i've got a set of isspro ev1 gauges all setup already..so im in the middle of installing a seperate ev2 fuel pressure gauge that i just bought using their electronic fuel pressure sender on the back of the filter housing...
sender has a green wire, black wire, orange/red wire...in the directions they do not tell you what to do with this orange/red wire.. i would imagine it has to go to ignition but im not 100% sure..
further in the instructions they tell you to run a ground to the vehicle chassis, and orange wire to the dimmer switch, and a red wire to ignition? im not following what this seperate red wires function is?
my problem is the gauge illumination works fine, but the gauge itself doesnt read anything..when i jump the orange/red wire coming from the sender to the ignition the gauge does read 85psi which i can't imagine is right? thats with the truck idling...
any help is appreciated..
Old 04-22-2012, 02:07 PM
nvevermind i got it now..i was sent the wrong instructions..
