Fuel Pressure Question? - Ford Powerstroke Diesel Forum
Old 04-21-2012, 02:29 PM
I installed the FRx(fuel rail crossover) from Riffraff on my 2001 F250.The instructions recommends the 62-65 psi spring in the fuel pressure regulator block.The other springs are 58-61 psi and 67-70 psi.I installed the 62-65 psi spring in my truck and it almost seemed like it tamed the truck down.Any ideas or recommendations on springs?My truck has sct w custom tunes,4" mbrp exhaust,Afe intake,Garrett 38GTPR turbo.Do I need to install bigger spring or is this safe for my truck?
Old 04-21-2012, 02:43 PM
Well it should quite it down, but if you feel its weaker try a different spring, that one might be weak
Old 04-21-2012, 03:27 PM
It is a brand new set of springs.I just dont wanna blow anything up,lol.Why do they recommend the middle set of springs?Anybody using this kit?If so,which spring do you use?
Old 04-21-2012, 11:18 PM
just because its known new doesn't make it a known good part
Old 04-22-2012, 02:54 PM
Okay the springs are fine.Physically look like nothing wrong with them and feel fine.No one out there running the Riffraff FRx kit?Need Help?
