Odd.... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-17-2012, 06:12 PM Thread Starter
floorboy's Avatar
Odd....
Been having trouble starting lately (40*+) I have 290,000 on it and have never touched the g.p's so I figured I would just put some in without testing them. Found a couple bad ones on the drivers side. When I moved the heater hoses (gently mind you ) this is what I found.
Looks like it has been that way for a while as there is dirt on the gasket underneath.
Am I missing something???? Wouldn't that kill four cylinders as well as the gp's???
Idk maybe I bumped it but unlikely as its way down in there.
Gp's test .6 .6 .6 2.5 I have decided to leave them till I have time to do the o rings too because it looks like a pia to get at them.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #2 of 4 Old 04-18-2012, 06:07 PM
aflores's Avatar
that's the plug that goes in through the valve cover gasket right? Goes to the glow plugs and injectors. Mine came loose on the passenger side and it definitely shut off those four cylinders.
2001 F250, Lariat, SC, SB, 4x4
DP Tuner, S&B Intake, FRx, Gauges, 4" turbo back straight pipe,ZF6 swap, SB Clutch, 3.73 gears
aflores is offline
post #3 of 4 Old 04-18-2012, 06:16 PM
A somewhat common problem. Try this: 50 cent mod - Ford Truck Enthusiasts Forums
Good luck!
2014 F250 Platinum
BakFlip F1
Line-X Bed Liner
WeatherTech Floor Liners
WeatherTech No-Drill Mud Flaps
DeeZee Tailgate Strut
5" Shorty Antenna
Big Wig rear anti-sway bar
Firestone airbags
B&W 18K Patriot 5th Wheel hitch
SOLD: 2001 PSD 4x4 Platinum Edition Lariat Auto CC SRW
Too Much To List
kep5niner is offline
post #4 of 4 Old 04-19-2012, 06:49 PM Thread Starter
floorboy's Avatar
I actually did the .50 well $.25 mod on the drivers side after I had a miss and took it to a diesel shop. I told him to check the harness but he put an injector in instead. When I went to pick the truck up after hours it had the same miss again. Researched it and took it apart and fixed it myself. Luckily he told me which side was acting up. I got him to refund my $550 and take the injector back out. I shoved a couple nails under this one for now since it is on the outside. Will mess with it more when we do the orings. Thanks. Maybe I did pull it off when I moved the heater hoses.
floorboy is offline
