SQUEAK WHEN TURNING TO LEFT? - Ford Powerstroke Diesel Forum
Old 04-15-2012, 05:14 PM
My 99 F250 is making a squeaking noise when driving and turning to the left. Once the wheel is starightened back out it goes away. Does it most of the time when turning to left. Can't get it to do it when truck is on jack stands though. Was told it may be the wheel bearing starting to go out. No play as of right now though. Any ideas or what else to check?
Old 04-16-2012, 04:56 PM
Bump..............
Old 04-16-2012, 06:41 PM
pretty much does sound like a wheel bearing!!! Couldnt really be much else, i mean ball joints just pop when you go around a corner or even break if they are bad enough.
Old 05-09-2012, 06:42 PM
Any other ideas. I can't get this fixed. Still no play anywhere but still squeaking.
Old 05-13-2012, 07:06 AM
NOT a Democrat
Wheel bering (dry?), tierod end.
Old 05-13-2012, 08:52 AM
I kinda think maybe wheel bearing but it has no play yet and I hate to replace it if that is not it. The tie rods seem good. Any other way to tell if its wheel bearing other than the hub assembly having play?
Old 05-18-2012, 06:09 PM
Bump.............
Old 05-18-2012, 06:24 PM
It could possibly be a u-joint, just a thought. Also the wheels bearings are the none serviceable type you would need to buy a whole hub if its that. But before you spend 400+ dollars on a hub I would check the u-joint, it maybe greaseable.
Old 05-18-2012, 06:50 PM
Let me know if you do figure it out. Mine is doing the same thing.
Old 05-18-2012, 06:57 PM
I don't think it could be front u joint though because it does it with hubs unlocked and the u joints are not spinning correct? Could it possibly be a rear driveshaft u joint that only squeaks when turning left?
