Old 09-26-2007, 02:39 PM
JHALL JHALL is offline
White/Grey smoke during acceleration?
I've searched for this complaint, but everything I've found is on start up and 99% of the threads are with 6.0's. And I didn't put it under problems because I don't actually know if it's a problem or not.
I have an early '99 F-250 7.3 w/ just under 200k. I bought it just last week, and it already has a Superchip tuner installed. It was set on the performance/tow tune and I just bumped it to the Hi-performance tune the other day (even though it is not that impressive). With either setting, under hard/full throttle it sometimes blows a little bit of white/greyish smoke, then stops. It's usually only a once or twice thing every outing. The majority of the time it's pure black smoke. But under light throttle, no smoke at all. And on start up there is no smoke what so ever, and starts right up. I'm not losing power or anything. I'm not sure when the fuel filter was last changed, could this be a possibility? What could cause white-ish smoke at times and black smoke the rest? Any ideas? Thank you!!!
Old 09-27-2007, 05:18 AM
Any ideas? Pointers? Should I not worry about it?
Old 09-27-2007, 07:22 PM
Could it be an issue with the turbo? Any ideas at all?
Thanks!
Old 09-27-2007, 07:24 PM
westcoaststrokin westcoaststrokin is online now
No clue but now I can bump for ya!
Old 09-27-2007, 07:31 PM
mschn99 mschn99 is offline
Banished
my guess...especially given the year...would be injector o rings.....
if it has a hard time starting when it gets a bit colder...i would definately say thats the case...
Old 09-28-2007, 07:23 AM
Thanks for the reply Marc...I don't think it's gotten cold enough yet to determine whether it hard starts in "cold weather," but it's gotten down to 40's or so in the morning and fired right up w/ no white smoke or anything, so I don't know. It's mainly when I get on it just going down the road, sometimes it's whiteish smoke sometimes it's pure black.
Old 09-28-2007, 03:24 PM
So is it something I shouldn't worry to much about until it gets cold out and see if it's harder to start??
