Which oils
Ok so I am planning on changing everything over to synthetics since I have hear nothing but good things, and would love to have that 8-12k intervals I have been hearing about. I will be using Amsoil since I have heard the best about them. I will run 15w-40 for engine oil but not sure which specific type since there are so many. Also what gear oil do I use in the front and rear diffs, as well as the transmission and transfer case. Also I think I want to run the BHOF on the engine, any thoughts on that? Any help would be appreciated, thanks.
On my Dmax I have the 75w140 severe gear oil front and rear but you really don't need the serve gear oil up front. For the tcase I run synchromesh manual tranny fluid. I can't remember what the atf is but I still have the jug.
I can check and see if my atf works for both and what engine oil I have, its 15w40 but didn't know there were any other specs. |
You can run Amsoil multi ATF in the trans and the transfer case.
If you need a deal on some, send me a pm.. Sent from my ADR6400L using AutoGuide.Com Free App |
There are like 3-4 different products listed under each of the components on their site. Just don't know which ones to get.
Schaeffers 9000 5/40 in the engine, schaeffers all trans in the tranny, transfer case, power steering, redline 75/90 in the front diff 75/140 in the rear.
I run Amsoil throughout my trucks. Severe Gear 75-90 front, 75-140 rear, ATF in the tranny and transfercase, and the 15-40 engine oil that is for the pre-dpf vehicles and has the blue label. I have no input on that air filter setup, I run an S&B on my 01 and also have good experience with AFE.
I'm running the Premium Heavy Duty Diesel and Marine 15W-40. If you go with the BHOF, make sure you have a stock sized filter. (Amsoil EAO99) It's rated the same at 15 micron at 99%. The ELF7405 would not fit my truck. I bought 2 of them. Spent over an hour and a half with both of them under the truck. Couldn't get either to get on the threads. The start of the threads on the filter didn't look half as good as the Amsoil one and I think that may be my problem. I could feel it slide into the threads (motor side) but it wouldn't grab, even with me pushing up on it, turning it 4-5 times. I will be calling Donaldson to see if they had a bad run or something. The Amsoil one slid right up and caught within a half turn.
Honestly with UOAs any properly running 7.3 should be able to make 8-12k OCIs even on cheap fleet grade oil...the factory OCI on the T444e was 10k. Granted the oil pan is slightly larger but only 2 quarts at most. You should have no problem getting 8-12k out of any of Amsoils diesel oils. |
I ran 30K on my IDI 6.5 and it was just getting to the slightly worn margin according to samples. I am running dual bypass though.
10-15 on a "tight" 7.3 should be doable. |
The biggest thing to watch (other than the wear numbers on a properly running truck) is shear, while not the shear factory the 6.0 (unless your running a tune with a high duty cycle on it or dual HPOPs) is, a 7.3 can beat up an oil with the best of them. That being said going from a 40wt to a heavy 30wt without an acceleration of wear isn't anything to get worked up over.
