Electrical troubles - Ford Powerstroke Diesel Forum
Old 04-10-2012, 05:04 PM
Electrical troubles
Does anyone have or know where to find a wiring schematic for an 01 7.3 that would include the exterior lighting and speedometer paths?
I have an issue where everything works on the truck except for brake lights, because the brake light fuse is blown. When I replace the fuse, the brake lights work, but my ABS light comes on, speedo bounces a few times and then dies and the turn signals quit working...remove fuse or wait for it to burn out, and then everything is working great (except brake lights).
Have checked all other fuses and bulbs, am figuring that I have two wire that are touching somewhere in the loom or at a connector, I have narrowed down the rear light/brake light wiring, but need to know where the speedometer wiring might come into contact with it.
Old 04-15-2012, 05:31 AM
Well, at the advice of a friend of mine, I started checking the trailer light wiring. Sure enough, there were cut wires everywhere, so I taped them up and disconnected the main connector and everything started working again
Now I just have to go back and re-wire all of the trailer lights correctly, then I can start working on the fun stuff.
