psi levels
What type of psi levels could I expect with a Hypermax turbo?
More info please
Stage 2, 160cc injectors
Stealth 1 HPOP Air Dog fuel system AIS intake 4inch exhaust Anything else? |
depends on how big its modded, and psi aint everything, boost is a measure of restriction, not volume. 35 to 40 dependin on nozzles and tunin and whether or not your hpop can keep up. also the air dog is not a fuel system. stock fuel system with a regulated return will flow enough for 160's air dog is junk
If you don't want to make too much then regulate it. That's a guarantee
What do you have against a 38r? Its the only drop in for your truck, everything else will have a new mount and the cost will be like double. Im runnin at over 450 horse with stock head bolts, val e springs, and fuel pump.
I've got nothing against the 38r, I just wanted something different. Touche. I was actually tossed between the 38r & Hypermax. Think I'm gonna go with the 38r.
