  #11 (permalink)
Old 09-26-2007, 12:55 PM
rcoker6493 rcoker6493 is offline
Originally Posted by FionaThe02PSD View Post
The BBH has a very stiff spring and it adjustable to dial in the exact maximum boost that you want. Even removing the "Red line" the stock unit will start to open as the spring is weak.
The ATS housing will eliminate "Surge" that is associated with performance tunes.
The stock will remain shut if you extend the adjuster arm al the way out forcing the waste gate to stay closed.
  #12 (permalink)
Old 09-26-2007, 01:39 PM
FionaThe02PSD FionaThe02PSD is offline
Sounds like a fair amount of work for a bandaid but I guess it could be done. Driving the stocker without the wastegate can be a little rough on the turbo but it can be done as long as you do it knowing that you are shortening it's life. By how much, I don't know.
  #13 (permalink)
Old 09-26-2007, 03:45 PM
CSIPSD CSIPSD is offline
There is also the Turbomaster Wastegate control rod... Cheaper then the banks and easy to ajust...
FYI... You dont want to "extend" the WG rod, you want to shorten it to make it tighter.
  #14 (permalink)
Old 09-27-2007, 08:39 AM
^^^^^^^True!
  #15 (permalink)
Old 09-27-2007, 10:25 AM
jhp7.3 jhp7.3 is offline
I agree i wouldn't want to do away with the waste gate completly, but holding it closed a little longer seems like a good thing, plus the map sensor will defuel @27 psi
  #16 (permalink)
Old 09-27-2007, 12:56 PM
The Map sensor will defuel at 22lbs. not 27.
  #17 (permalink)
Old 09-29-2007, 07:59 PM
Your right you need to shorten the ROD.. When you add 140+ power to a motor it shortens the life of a lot of things.. Just watch the Boost levels...
  #18 (permalink)
Old 10-03-2007, 11:42 PM
makaveli200369 makaveli200369 is offline
hey guys..what is the stock boost level of the truck? Don't these high performance chips increase the boost past 22lbs? If not..how do you get around this?
Also I was curious if you upgrade the turbo without injectors but have a TS 140HP tuner chip..will that supply enough fuel? If not what will happen.....either way if you have a upgraded turbo at stock boost levels wouldnt that lower EGT's and be benificial
  #19 (permalink)
Old 10-03-2007, 11:51 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
stock boost is about 18 psi on a 7.3
yes the chips increase boost past 22 psi and to get around that, you need a MAP fooler.
as for the turbo questions - i'll let the other guys answer those
