AMSOIL Filter problems.. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-04-2012, 05:18 PM Thread Starter
firemedic5586's Avatar
According to AMSOIL's web sight their 25K mile filter for my 02 7.3L is an EAo99. Well that dog don't hunt, I have a few quarts of oil on the driveway to prove it.. The NAPA Gold 1734 screws right on with out a hitch.. Has anyone else had problems with the AMSOIL filters?
2002 F350SD Lariat 4x4 CCLB SRW.
Mods; Wicked wheel, Turbo-Master, Zoodad, EBPV deleate, DIY CAI, 5" Turbo Back Magnaflow, Edge Insight CTS, PHP FU Chip, Coolant Bypass filter, 203 stat, Cat ELC, Transmission Filter System, Tru-Cool transmission Cooler, Truxedo Tonneau cover, HID headlights & fogs, LED's for everything else. Rear view cam, Ranch Hand bumper, TorkLift; SuperHitch, Camper Jacks & Stableload.
firemedic5586 is offline
post #2 of 12 Old 04-04-2012, 05:25 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What was wrong with the filter?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 12 Old 04-04-2012, 05:34 PM Thread Starter
The filter doesn't screw all the way on.. There is about 1/8 gap between the oil filter seal and the engine block..
post #4 of 12 Old 04-04-2012, 09:00 PM
JSchuricht's Avatar
I have a bypass on my SD but I just put a EAO99-EA on my OBS and haven't spotted any puddles under the filter.
JSchuricht is offline
post #5 of 12 Old 04-05-2012, 04:19 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I wonder if that filter was bad or maybe it was double gasket-ed? As in the old gasket stayed on the filter mount?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 12 Old 04-05-2012, 04:32 AM
Term3's Avatar
Quoted: 2 Post(s)
Is it possible that the short pipe that the filter screws onto is not completely screwed into the filter base. I've seen it happen on water filters several times. Amsoil makes a real good product so any problem at all surprises me.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 12 Old 04-05-2012, 05:46 AM
drstephennix's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to drstephennix
I never had a problem with mine on my 7.3. Did you cross-thread it maybe?
2013 F350 Platinum LB 4x4
35" MT's
74k miles
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #8 of 12 Old 04-05-2012, 06:11 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
or you just got one with bad threading...
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #9 of 12 Old 04-05-2012, 06:44 AM Thread Starter
It wasn't double gasketed. The filter "Bottomed out" and felt just like they always do when you snug them up. Threads looked fine. This is the second time I have had problems with the same filter on this truck. 1st time the threads were messed up, i was told I crossthreaded I found that hard to believe but anything was possible. I knew it was messed up so there wasn't any oil spraying any place. Now after mysecond attempt something is really fishy.
post #10 of 12 Old 04-05-2012, 07:04 AM
Quoted: 2 Post(s)
Maybe they sent the wrong one. Could have had a batch of them labeled with the wrong part # or something
35" MT's
74k miles
