7.3 trans cooler swap - Ford Powerstroke Diesel Forum
Old 04-03-2012, 03:35 PM
I purchased a used 31 row trans cooler to put in my 99 7.3. I have two questions. Do I need to flush out the 31 row cooler before I put it in and if so what do I use to flush it out with? Next question is when I hook the new lines up to the 3/8 to 1/2 adapter, what kind of material should the adapter be? Should I buy one that is copper, steel, aluminum, I have no idea please help!
Old 04-03-2012, 03:42 PM
The flush - I'm not sure - You might want to call a radiator or transmission shop for the answer.
Adapters - the ones I bought were brass, if I remember right.
Old 04-03-2012, 04:37 PM
Yeah same here, brass fittings from home depot is what I got.
Old 04-03-2012, 06:25 PM
Where did you get the new transmission line?
Old 04-04-2012, 05:38 AM
You can get 1/2 inch line from any auto parts store, just make sure its oil rated.
Old 04-04-2012, 07:53 AM
I got my rubber 1/2" line at Napa Auto Parts here locally - it was Marine grade hose.
