Additives
What is your thoughts on fuel additives and oil additives? Are they bull****? Do some work but not others? Which ones? I'm kind of iffy about fuel additives and have no idea about oil additives.
As you might imagine, this topic has been covered many times.
If you go up to the "Google Custom Search" just under the POWERSTROKE.org logo at the top of the page and type in "Fuel Additives" - You'll get a list of threads where it's been discussed and can find the answer to your questions. |
whoops, my bad. I guess I should have thought of that.
NO problem... If you still need help after that let us know
Just so you arent left hangin I use Lucus religiously....
Took my 8920 Case IH with 6,000hrs from using/leaking 1 gallon of oil/10hrs and cut it in half. Recommended overhaul on those engines is ~5,000hrs. Figure its gotta help anything else I own that leaks or uses oil. I also run injector cleaner and top off my hydraulic oil in my tractor with their hydraulic oil conditioner. |
