dif fluid - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-02-2012, 02:14 PM Thread Starter
jcfuzzdog29's Avatar
dif fluid
Got a rear dif cover was wondering what kind of fluid you guys run in them front and rear if you guys use the same in both or what
jcfuzzdog29 is offline
post #2 of 10 Old 04-02-2012, 02:18 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
I use all Amsoil products. Depending on your setup here is the fluid for either.
Limited Slip Differential, Rear Dana 80......GL-5*
All TEMPS......75W-90 [1] [2]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Standard Differential, Rear Ford 10.5 RG......GL-5
All TEMPS......75W-140 [1]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Limited Slip Differential, Rear Ford 10.5 RG......GL-5*
All TEMPS......75W-140 [1] [2]
Standard Differential, Rear Dana 80......GL-5
Differential, Front Dana 50......GL-5
Differential, Front Dana 60......GL-5
Standard Differential, Rear Dana 135......GL-5
All TEMPS......80W-90 [3]
SAE 80W-90 Synthetic Gear Lube (AGLQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Limited Slip Differential, Rear Dana 135......GL-5*
All TEMPS......80W-90 [3] [2]
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod,
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
Diesel Site Coolant Filtration System
dusted4eva is offline
post #3 of 10 Old 04-02-2012, 02:53 PM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Front Mobil 1 75w-90
Rear Redline 75w-140
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #4 of 10 Old 04-02-2012, 07:22 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I had Royal Purple 75w140 in both the front and rear for 50k, just switched to Lucas Oil, 75w90 up front and 75w140 in the rear. Both were/are great for me.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #5 of 10 Old 04-02-2012, 07:27 PM
redline 75/140 rear, 75/90 in the front
bruce51d is offline
post #6 of 10 Old 04-03-2012, 01:42 PM Thread Starter
how many quarts are in the front and rear difs
post #7 of 10 Old 04-03-2012, 02:02 PM
Quoted: 17 Post(s)
Front = 5.7 pints
Rear = 6.9 pints SRW
post #8 of 10 Old 04-03-2012, 02:10 PM Thread Starter
Does adding a new dif cover have more of a capacity like a mag hytech ...thanks you guys are very helpful on this forum. unlike other forums i have been on.
post #9 of 10 Old 04-03-2012, 05:48 PM
tubular031's Avatar
I have the magtech on mine. It goes from 4 qt to 6 if I remember right.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #10 of 10 Old 04-08-2012, 05:23 PM Thread Starter
i think with the mag hytech its 4 quarts up front and 6 quarts in rear right
