Starting weird
I took my truck into the dealership for a fuel leak, I didn't have time to mess with it and had them do a coolant and tranny flush. I put new batteries and gpr a while ago. It was starting great super fast, but now it has been really sluggish almost like the batteries are dead or gpr isn't working. So, is my starter going bad or did those a-holes screw something up. I noticed the yanked my red waste gate line out of the plug and my truck is leaking coolant. So it's going back today should I have them look at it?
Sent from my iPhone |
I would - No telling what happened to other stuff while they were working the previous issue.
Ya they clearly weren't very gentle. I'm thinking maybe they didn't hook up my gpr very well since the difficulty of starting seems dependent on temp. More or less
Leaking coolant? Your oil cooler may be the culprit for that. Take a look and youll see if its leaking. Usually they will only leak when cold.
They diagnosed it today saying that it was coming from the thermostat and housing area and thought it could be a bad water pump too. Well I didn't believe them since I put a diesel site and 203 t-stat in. So I told them to clean the area and see if they could get it to seal.
What do you guys think I should do? Replace the the water pump and thermostat? Also, they think my starter is going bad but were going to tell me once they actually diagnosed it. |
I would do your own diagnosis! a coolant leak shouldn't be too hard to find. doesn't mean you have to do the job but at least you will know what needs done.
quit taking your truck to those butt pirates. It is apparent that they don't know what they are doing or at least don't respect your property. your engine should crank relatively the same speed regardless of the condition of the gp circuit so, does it crank slow or start hard? there is a difference. If it is cranking slow then I would look into the starter circuit including, BATTERIES, starter solenoid, ALL cables and connections including the grounds on the block, and last but not least, the starter. If it is starting hard, well, I will just wait for an answer! lol |
Clean the connections first then have the batteries checked. Just be sure you disconnect and test them individually. Leaving them connected together will give a false read.
If that don't fix it then have the starter tested. They do get weak over time. Keep in mind that advance auto can't test these starters. Their machine isn't strong enough. Try an actual starter shop. If you need a new one get the three bolt model even if you have the two bolt. They're bigger, stronger and last longer. That's my .02 from experience. Sent from my Autoguide iPhone app |
