Pic of LED Console '99 F350 - Ford Powerstroke Diesel Forum
Old 03-31-2012, 04:14 PM
My LED overhead is not working, so after reading various threads, I pulled the console.
No chips fell out, but one was a little bit loose. But after looking at the LED screen, there was a dark spot on it (see picture).
My question is: Is there a good change that the LED is shot and not worth going and buying a solder gun? I have read where some people tried fixing only to find out the LED screen didn't work.
Thanks for the help/input.
Old 03-31-2012, 07:14 PM
The burn mark is normal. Don't buy a solder gun, you need a iron. A gun is for larger work.
Old 03-31-2012, 07:38 PM
It's an LCD screen.
And the resistors are what come loose. Just resolder them on, and you'll be good.
Old 04-01-2012, 05:27 AM
Thank you for confirming this. Made the note of LCD screen...lol dont know what I was thinking writing LED!
I will get a small iron today. Thanks again!
Old 04-01-2012, 07:47 AM
There is a write up somewhere about what resistors they are if you lost them. But if not, you should be good.
Old 04-01-2012, 06:04 PM
I was able to solder one of the chips that was not fully attached and cure a few others just in case...when I plugged it in it worked.
Thanks for the help.
Any way to reset the mpg or do I need to fill up to have it reset?
Old 04-01-2012, 06:13 PM
Found it on here (press both buttons t reset mpg)
Old 04-02-2012, 04:10 AM
Not like the MPG reading is that correct.
Old 04-06-2012, 09:26 AM
FORD SUPERDUTY F250 F350 OVERHEAD CONSOLE COMPUTER REPAIR WE HAVE REPAIRED 3000+ | eBay
