Old 09-23-2007, 07:54 PM
nevada diesel nevada diesel is offline
Glow Plug Relay? Truck won't start.
I have a 2000 7.3 that for one reason or another is neglecting to start. It has yet to get to cold here and the other day when I replaced my old headlights with new ones I had to remove the batteries to get access to the old headlight bolts. Immediatley following reconection of everything it would not start. I waited a bit and wiggled the terminals and it eventuallied turned over. I thought it was that but apparentley there must be something more. It now will turn over but not fire. Any suggestions!!!
Old 09-23-2007, 08:04 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
A few easy things you can check first is the fuses. Make sure your batteries are fully charged, and if you have a meter check to see if you are getting 10.5 volts while cranking.
