Early '99 ? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-28-2012, 04:36 PM Thread Starter
Early '99 ?
Is there any significant issue or difference in the early '99 PSD vs the late 99-2000 models? Any reason to stay away from the early 99's?
Thanks
stickk is offline
post #2 of 11 Old 03-28-2012, 04:45 PM
CowboyCody's Avatar
Quoted: 3 Post(s)
Not that I know of... There's not much difference between them. They have a slightly different turbo wheel I know and v8 powerstroke fender badges instead of on the door. I'm sure there are other things... But I don't know all of them. No reason to stay away though, It has a 7.3 i say buy it!
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2000 Excursion Limited, S&B intake, GTP 38R turbo, Billet Transmission upgrades.
CowboyCody is offline
post #3 of 11 Old 03-28-2012, 04:45 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Yes. Biggest differences are the Hpop is a little smaller(15* vs17*), the front suspension is a little different. The Turbo pedistal is shorter, and the up pipes off the manifolds are shorter. The Turbo they say is smaller in the early, but I don't think so, and cannot find size differences. The e99 has the wicked wheel as standard issue. The later model went to a different wheel. The intakes to the heads are a little over 2 inches in the early, and they are 3 inches in the late,
Pcm is different,
I have an early and I don't consider it bad, the later models have a larger amount of drop in parts, ESP when it comes to turbos, and intakes, and the y pipe coming form the Turbo( cfm+intake). You can usually find the parts to swap one over to later model specs, but if you have the chance you might as well get a later 99 and be done with it. There is a thread that's a sticky in the the early 99 section, its alot of info. But its a good read.
Sent from my Acer Android Tablet
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 11 Old 03-28-2012, 04:45 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Differences between early99 and late99-03 trucks
Triple post attack.
I click post, and I have to go way down the page to find mine.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 11 Old 03-28-2012, 04:47 PM
Doesn't Even Care
Quoted: 69 Post(s)
There is the thread I was talking about.....
Nick
"The Mistress"
post #6 of 11 Old 03-28-2012, 04:59 PM Thread Starter
Thanks, I did read and print that info earlier. As long as there aren't any " stay the hell away from the early 99's" out there I won't worry about it. I've had 2 PSD's and my last 2 trucks have been CTD's. Love that Cummins but for what I can afford now I am coming back to Ford to get a real cab, CC. I would like to get the 7.3 to the power levels of my '06 CTD 6 sp which had a tuner, 75hp, and 5" TB exhaust. Is that a reasonable goal, ie $$$$, or too much too ask for on a budget, say 2k. I will not be looking for or purchasing an auto trans. Ha, I said that with the 99 CTD I bought last fall but I ended up with one!!!
Thanks guys.
stickk is offline
post #7 of 11 Old 03-28-2012, 05:07 PM
Doesn't Even Care
Quoted: 69 Post(s)
Oh heck no, you won't get close to that power level on 2 grand.
You are looking at hybrid 238-250 CC injectors which can be 2000 or more alone. Then comes Turbo, which can range from 1450 for a 38 r up to 2500 for a complete modded h2e( better) Turbo, them comes fuel system at 750, and then a high pressure oil pump at 600, and guages and custom tuning which the skys the limit here, exhaust and intake can run you 600 combined. That's new prices for each of that stuff and some of my figures may be a little off. But they are close. Its not cheap at all to make 500 rwhp on a 7.3. You can make 400 pretty easily, but the jump from there will cost you. And if you are pushing 500, you might as well add valve springs, pushrods and studs, which if you do yourself, the parts alone will cost you a grand. Before you know it, its a freak in money pit.....ask me how I know, hahahahahahaa
Nick
"The Mistress"
post #8 of 11 Old 03-28-2012, 05:11 PM Thread Starter
Not looking for 500 hp at the wheels. Closer to say 325-350. That's about what my '06 CTD was and it was plenty for what I did.
Thanks!
stickk is offline
post #9 of 11 Old 03-28-2012, 05:18 PM
Doesn't Even Care
Quoted: 69 Post(s)
Oh, well, yeah for 2 grand you can get guages, a good 4-6 position chip, exhaust, intake and have money left over and get that. I didn't know exactly what tpower level you were talking about. Just fyi, I have a d66(66 mm Turbo) stage 2 160cc injectors, conservative tuning from PHP, adrenalin hpop fuel pressure regulator spring intake and exhaust and I made the numbers in my sig. My truck probably has 450/1000( or that's what im going for) in it with aggressive tuning,
Nick
"The Mistress"
post #10 of 11 Old 03-28-2012, 06:35 PM Thread Starter
Is there a different power output for the 99-2000 std trans models like the 01-03? I think the later was 275hp ilo 250hp for the autos.
stickk is offline
