need advice! - Ford Powerstroke Diesel Forum
Old 03-28-2012, 03:48 AM
need advice!
My 99 7.3 makes a fairly loud fluttering noise when towing up a hill. I'm guessing its the turbo or waste gate but is it normal? Is there anything I can do to fix it like a wicked wheel IR afteemarket waste gate? All the truck has done to it now is a super chip
Old 03-28-2012, 04:16 AM
yea its normal. ww is supposed to fix it but i dont know how good they work but im sure someone here has one that can tell you better than me.
Old 03-28-2012, 04:26 AM
I've heard you lose a couple pounds of boost with the wicked wheel.
Old 03-28-2012, 04:35 AM
It's turbo surge.
The SD wheel tries to force more air in at a certain boost level but just can't due to the fluid dynamics of the air and blah blah stuff compression.
Anyway, the wheel is not efficient in that range.
A WW is better at that range, but can lose a pound or two of boost. Big deal.
A ported shroud is guaranteed to fix it.
Old 03-28-2012, 05:05 AM
Ported shroud and ww?
Old 03-28-2012, 07:40 AM
Yes? What about them
My Samsung SGH-I997 made me send this.
Old 03-28-2012, 07:50 AM
Should I do them both to fix it or just one or the other?
Old 03-28-2012, 09:15 AM
You can try a ww, but just know it might or might not solve the issue.
Ported shrouds are expensive. What are your plans with it
Old 04-02-2012, 10:05 AM
WW fixed mine until bigger injectors went in. most people I have heard from say the ww fixed their surge. the ones that say it didn't seemed to be the ones that towed really heavy pretty often.
Old 04-02-2012, 10:46 AM
I tow fairly often but never very heavy loads. I ordered the ww and the ported shroud also so hopefully that will take care of it.
