Old 09-23-2007, 09:56 AM
volsfan411 volsfan411 is offline
Leveling My 99 F250
I want to level my F250 however don't want to spend the $$ right now for a leveling kit if I don't have to. I work at a machine shop so, I can build shackles to lift the front of the truck up. I have seen a guy on ebay with some to lift the front up 1.5" but I need to go 2.5". Can I lift the front up 2.5" with out having to change anything like shocks or anything else right now and what are anyones thoughts on doing this?
Old 09-23-2007, 10:13 AM
dikdragon dikdragon is offline
2x4 or 4x4? i bought a 2'' leveling kit for my 2000 2x4 at -http://www.fatbobsgarage.com/cart/ $49
Old 09-23-2007, 10:14 AM
jblagg jblagg is offline
you should be able to get 2 inches if you fab up some shackles get the spec on the onse you found and build them a lil longer but a levering kit only cost about 3 bills
Old 09-23-2007, 10:17 AM
My truck is a 4x4
Old 09-23-2007, 10:36 AM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
Do a GOOGLE search for "99 F250 leveling kit" I found several that were availiable for my 350, that didnt cost alot. Or, ebay always works too!!
Old 09-23-2007, 10:39 AM
CUMMINS_KILLA99 CUMMINS_KILLA99 is offline
they do sell a 3in. shackle kit on ebay it drops the front and rear of the spring to get the proper angles not just the front like some kits. but i bought a 2 1/2 in. leveling kit from summit racing for 275
Old 09-23-2007, 10:55 AM
For the 350, you'd have to use a 3 1/2" leveling kit right? 2 1/2" is for the 250's am I correct?
Old 09-23-2007, 10:58 AM
I thought that the add a leaf leveling kits makes for a ruff ride + getting the wife to ok the $$ for a leveling kit is harder the leveling the trunk. lol
Old 09-23-2007, 11:09 AM
the kit i bought has 2 new springs completely and it ride like stock bug 3 inches higher. I love it mine is a 1 ton tho. it cost a lil more.
Old 09-23-2007, 11:20 AM
Logan Logan is offline
The Fat Mod
I put a single add a leaf under my 350 and it is good and level and rides like factory. Mine was found for under a hundo.
