  #31 (permalink)
Old 09-28-2007, 08:14 PM
volsfan411 volsfan411 is offline
Ok I think I under stand that but how do you know how much to lower the front of the springs. see pics and let me know if I am right please.
  #32 (permalink)
Old 09-28-2007, 08:18 PM
jostaman jostaman is offline
Smile half right
no both have to go down so lifts truck up
  #33 (permalink)
Old 09-28-2007, 08:19 PM
I forgot but how do you check your pinion/driveshaft angle to see if everything is lined up to spec after you have lifted it?
  #34 (permalink)
Old 09-28-2007, 08:24 PM
Smile how high
If not going to high you do not have to worry.
  #35 (permalink)
Old 09-28-2007, 08:33 PM
ok so I would have to make or buy a longer fixed hanger to move the shackle down. but it can't be a shackle or it will move. and I only want the back to be able to move. Ok I think that is what ppl are tring to say. No the question is how much, the same amount that I move the shackle up?
  #36 (permalink)
Old 09-28-2007, 08:42 PM
Smile
ok so I would have to make or buy a longer to move the shackle down. but it can't be a shackle or it will move. and I only want the back to be able to move. Ok I think that is what ppl are tring to say. No the question is how much, the same amount that I move the shackle up?
No you are moving both front and back down. and yes you not want front to move, just the rear.fixed hanger 4 inch longer, then rear 4 inch longer, =raises truck 4 inches
  #37 (permalink)
Old 09-28-2007, 08:50 PM
Like this?
  #38 (permalink)
Old 09-28-2007, 08:55 PM
Smile you got it
yepper thats going to move truck up. Right
  #39 (permalink)
Old 09-28-2007, 09:51 PM
Even thou I went thru all this to understand I think I am going save up and go with the add a leaf because I think it will be safer in the long run and finding or making a fixed front hanger will be much harder then making shackles and no chance of messing up the drivabilaty. I HOPE to get this done soon and get new tire so I will post before and after pics.
  #40 (permalink)
Old 09-30-2007, 03:39 AM
rankroddin250 rankroddin250 is offline
yeah rear suspension geomitry isnt as important as the front end. the adaleafs arent that expensive.
