Bearing R&R - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-23-2012, 04:29 AM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
Bearing R&R
I've seen plenty of write ups on bearing changes for 4wd, but what about 2wd?
I've helped on this once before, but can't remember much. Is it basically like doing trailer bearings?
Tire off. Brake caliper off. Dust cap off. Cotter pin out. Spindle nut off. Pull washer and outer bearing. Pull hub. Pull inner bearing and wheel seal. Clean. Pack with grease. New wheel seal. Reinstall?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #2 of 3 Old 03-23-2012, 06:24 AM
yup that sounds about right
2000Superduty7.3 is offline
post #3 of 3 Old 03-23-2012, 05:54 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
That's what I figured from what I remember the first time. Now I have a shop that I can use to do all the work and a bearing packer, etc.
Except the stupid hub is part of the rotor
4R100, 2wd
330,000 + miles
jesilvas is offline
