benefits of ebpv delete? - Ford Powerstroke Diesel Forum
Old 03-18-2012, 02:30 AM
it looks like a cheap mod is there any great benefit to doin ebpv delete i know people do because of leaking pedestal accuator but does it improve spool or sound? also the AIH what is the benefit of deleting it?
Old 03-18-2012, 06:39 AM
Slightly faster spool ups, no more annoying sound, no more leaks.
Old 03-18-2012, 07:25 AM
If you find pics of how big the butterfly valve is in the exhuast, you'll see it does limit flow a bit. So a little more exhaust flow is never a bad thing.
AIH delete is just getting rid of the dumb thing that hardly comes on. Idk of anyone who's tested actual flow numbers, but it should help smooth air flow out
Just takes a cummins drain plug to fit it. So no reason not to. Unless you're driving around in -50*F.
Old 03-18-2012, 07:59 AM
i think im goin to do both never have to work on this reliable beast and im gettin the itch to tear something apart!!
Old 03-18-2012, 05:44 PM
I run my boost line off the AIH delete. 18 bucks for the plug
Sent from my C771 using AutoGuide.com App
