Engine compartment question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-15-2012, 04:20 PM Thread Starter
adavis11's Avatar
So I changed my fuel filter today and apparently I did not have the cap on tight enough so when I went to start the truck it gave my engine compartment a diesel shower. The question is will the diesel fuel hurt any of the wiring or components?
2013 6.7 Powerstroke Platinum
adavis11 is offline
post #2 of 6 Old 03-15-2012, 04:58 PM
zrain25's Avatar
I had that happen to me. The old oring was still on the bowl and I put the new cover with a new oring and so the two orings showered my truck till I heard fluid dripping. My truck is fine I think you will be ok it
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #3 of 6 Old 03-15-2012, 05:18 PM Thread Starter
adavis11's Avatar
Did you wash out your engine compartment after it happened?
adavis11 is offline
post #4 of 6 Old 03-15-2012, 05:34 PM
zrain25's Avatar
I think I did like but not because of the fuel reason. The fuel will evaporate. The only place were it won't evaporate they fast is the valley but that won't hurt anything. I think I washed it like a week late like I said not the fuel reason
zrain25 is offline
post #5 of 6 Old 03-15-2012, 08:13 PM
It will be fine. There are wires in the fuel tank for the fuel sending unit and plastic harness to and they hold up just fine. If it were gas I'd be more conserned because of its flamiblity and a hot engine, but not a problem with diesel.
Jab018 is offline
post #6 of 6 Old 03-16-2012, 05:18 AM
Zaairman's Avatar
Quoted: 12 Post(s)
I stacked the two gaskets once also. If you pop the hood, have a buddy stand at the front of the truck to look for a leak, and key on, you will spray him with diesel. That was 5 years ago, nothing bad has ever happened from it.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
