Oil analysis came back from CAT.
So I can't figure out how to post a picture so ill type everything out.
Oil that was tested was Valvoline 15w40 wear metals Cu - 2 Fe - 61 Cr - 2 Al - 2 Pb - 3 Sn - 0 Si - 5 Na - 5 K - 5 Mo - 35 Ca - 1446 Mg - 597 Zn - 1285 P - 1081 Oil Condition ST - 26 OXI - 15 NT - 9 SUL - 18 W - N A - N F - N V100 - 12.8. According to CAT there is no action required to be done. What do you all think? This is the first oil sample I have done on this truck |
How many miles on the OCI?
OCI? Im guessing oil change intervals? And this was with 5,000mi
Yes, sorry. What were the driving conditions of the run? Towing? How much how often? Iron and lead are a bit high for that short of an oci, not out of the normal range I guess but a little higher depending on how the truck was driven.
Sorry I haven't been on in a while to reply. The truck gets driven hard everyday and has a lot of short drives too sadly. I pull a 20ft enclosed lawn trailer about once a wk with equipment.
Given how hard the truck gets worked nothing seems too out of place. The Iron is a bit high but not crazy high. The rule of thumb on Iron is under 100 ppm is fine, sounds like 5k OCIs are about right. No TBN but the oxidation number is not out of hand so no need to worry.
