the scangauge2 xgauge codes - Ford Powerstroke Diesel Forum
Old 03-14-2012, 12:04 PM
Alright guys, im sure that there are a few of you guys running the scangauge2 that can be bought from autozone for $160.00.
The crew on the 6.0 has an awesome thread started posting important xgauge codes so they can monitor certain parameters. So I figured I would start a thread so our trucks could get some love. I just picked mine up today, again..
I found some codes on their site to get us rolling.
http://www.scangauge.com/support/x-g...cific-xgauges/
So let Xgauge codes begin!!!!
So far I have these codes working on mine..
Engine Oil Temp:
TXD: C410F1221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFFD8
NAM: EOT
IPR Duty Cycle:
TXD: C410F1221434
RXF: 046205140634
RXD: 3008
MTH: 006400FF0000
NAM: IPR
Injection Control Pressure:
TXD: C410F1221446
RXF: 046205140646
RXD: 3010
MTH: 003800640000
NAM: ICP
Exhuast Back Pressure:
TXD: C410F1221445
RXF: 046205140645
RXD: 3010
MTH: 016C03E80000
NAM: EBP
Transmission Fluid Temp:
TXD: C410F1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Engine coolant temp:
TXD: C410F1221139
RXF: 046205110639
RXD: 3008
MTH: 00010002007F
Name: ECT (Engine coolant temp) (Reads double until temp reaches 127F)
FICM Main Power: (Volts) (Should be 47-48) (This one isnt working on mine, anyone have different codes?)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
Glow Plug Percent: (haven't tried this one yet)
TXD: C410F1221430
RXF: 046205140630
RXD: 3008
MTH: 0F5127100000
NAM: GP%
Old 03-14-2012, 12:15 PM
Some Scangauge II Codes for "Xgauge"
Old 03-14-2012, 02:22 PM
You could start with the ones already listed on Linear Logic's website
Ford Specific X-Gauges
Has EOT, ICP, IPR, Boost, EBP, IAT etc...
Old 03-14-2012, 03:36 PM
In my 02, here are the ones I know work. (Going from memory so this may not be all of them)
All of the ones in the 7.3 section from Scangauge's website.
EOT * This one is a bit weird, and there appears to be at least 3 ranges, where the temp will go up to 255 and then down to I think 127. As I understand it, only the one in the warm engine range gives a correct reading.
MAP * I only see up to about 19 lbs on this, curious what everyone else sees. (AKA, Boost is somewhere around 5 lbs)
MPG
MPH
RPM
TPS (Note, in cruise control the pedal stays up so the sensor reads 0)
Volts
GPH (Best not to look at this one! )
HP
EBP
TFT (Shows the actual temp and not what the dash needle says)
Baro (I think Boost is calculated using baro and map)
Glow Plug % (I thought they were just on or off but this number does change and goes to 0 after a minute or so)
Ones I know do not work.
Fuel Pressure (Not sure about the one labeled "Fuel Pressure (if no FPR)"
Any Ficm gauges
Trans gear
Trans gear ratio
Torque into Torque Converter
CHT
Old 03-14-2012, 04:41 PM
I just programmed the TFT using the codes from xgauge and I tried the 6.0 codes also, neither of them worked. I also tried EOT and it doesn't work either. No info appears, except for my value name.
Does this thing not pick up either of these for 2000 7.3s??
Old 03-14-2012, 06:06 PM
My EOT and TFT codes are as follows:
EOT:
TXD: C410F1221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFD8
TFT:
TXD: C410F1221674
RXF: 046205160674
RXD: 3010
MTH: 0000100080000
Old 04-01-2012, 06:31 AM
Boost is VERY flaky at best , at least in my experience. I set it up according to the way it said and see max of 13.5psi. Also while I'm just cruising I'll sometimes see 2psi (light on the throttle and barely enough to make .1 psi LOL) and also will see 2psi of boost sitting at IDLE. STRANGE :-_)
Anyone else experiencing similar type scenario?
Old 04-05-2012, 07:58 AM
Got my trans temp and engine oil temp working..
I'm averaging 150's for trans temp and 170-180 oily temp and the outside ambient temp is in the 80's... what is everyone getting via scangauge?
Old 04-05-2012, 08:01 AM
About the same.
Old 04-05-2012, 08:38 AM
Feedback Score: 5 reviews
Trans seems good
Oil is too low... supposed to be 190-198 when empty and warmed up...
What is your coolant temp? The scangauge shows it as "ftp" or something like that..
I know it starts with the letter "f"
