no start
So, I parked my truck a few days ago and now it won't start. It like the injectors won't even fire. Crank is good, batteries have been recharged just as a precaution.
#22 Fuse is good tach read rpm's so i haven't bother to replace the cps even though it could be a problem. have fuel pressure have oil WTS light does come on Thoughts? I can't easily get to the UVCH, and I don't have the energy, and I haven't checked the IDM. I am going to have the thing towed tomorrow. I thought I would post first in case I have missed something obvious. thanks |
Disconnect the tuner (if you have one...), unplug the ICP, check the IPR to be sure the "tin nut" didn't fall off (maybe tap on it some, might free a stuck pintle). You sound like you've already checked all the other stuff
i forgot to check the tin nut, thanks! hoping this thing will magically start tomorrow...
how much cranking have you done on it? is your HPOP reservoir full? fuel bowl full?
