budget guages
What brand guages on a budget? Seen some Sunpro at Pep boys.
I've never heard of that brand, so I'd be reluctant to get them. As far as budget gauges, glowshift would be what you're looking for. Though I would highly recommend saving a little while longer and getting some ISSPRO's. They're worth the wait and a vendor here can hook you up. Do it right, do it once.
If you have a smart phone check out quadzillas set up. xdp.com
You could also look at the 3 in 1 gauge by glowshift. I believe its ~$150 and digital readings. There's a few guys on here running it and are happy with it.
Sent from my DROIDX using AutoGuide.com App |
glowshifts have never given me a problem, 3 gauges and a pod for 200
if your on a budget go with these: 94-09 FORD Superduty 3 GAUGE KIT
The sct x3 is only a flash programer and will not monitor engine vitals ( oil temp - pressure - water temp - trans temp - egt's - boost ect ) rite, what sct product is it that will handle monitoring and cary tunes that are safe to run on a non studded 6.0 . I'm in Ca. but will be moving to Az. before I have to smog again, and do I need to have the egr setup in Az. or can I delete it. Sorry for the hi-jack but I see knowledge I'd like to tap into. Thanks.
I just installed my GlowShift Quad pillar and it works great. I have Egt, Boost, Fuel, Trans
Fuel pressure was the worst one to install because of the sensor adapter and sensor not having any room to work with. |
Glowshift is a good brand on a budget. Autometer is a good one too, though they are more expensive, they are also very good gauges.
Does the Glowshift kit come with all the installation hardware, wires, hoses etc...
