Going to replace all injectors - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-09-2012, 06:39 PM Thread Starter
So i have 2 injectors out 1 on each side of motor. So i am going to replace them all. I found a complete kit from Diesel Care and Performance. Ever here of them?? THIS KIT COMES WITH THE FOLLOWING:
2 VALVE COVER GASKETS AND INTERNAL WIRING HARNESSES, 8 GLOW PLUGS,
8 INJECTORS 8 SET OF RINGS TO INSTALL INJECTORS $1080.00
tripnbubbles is offline
post #2 of 7 Old 03-09-2012, 09:38 PM
if that is the place from memphis i would avoid
bruce51d is offline
post #3 of 7 Old 03-10-2012, 08:11 PM
Whats with posting this twice and see my comment in your other post about giving Full Force a try.
mgassel is offline
post #4 of 7 Old 03-11-2012, 11:21 AM Thread Starter
Yea i didnt think it went thru the first time. And thanks for the info on Full Force i will be buying them from full force for sure so any ideas on a cheep place to get the glow plugs under cover harnesses and gaskets?
post #5 of 7 Old 03-11-2012, 04:59 PM
Got mine from advance auto parts the gaskets were about 80 bucks with the wire harness for everything.
Buy Dorman - OE Solutions Diesel Valve Cover Gasket Kit 615-201 at Advance Auto Parts
The glow plugs costs about 12 bucks each get motorcraft they are called spark plugs for some reason at advanced Buy Motorcraft Spark Plug ZD11 at Advance Auto Parts
mgassel is offline
post #6 of 7 Old 03-12-2012, 10:09 AM Thread Starter
Great thanks. Any tips or tricks would be great. Ill try to find a thread about this
post #7 of 7 Old 03-12-2012, 11:21 PM
No real tricks I used a pry bar to pull out the injectors I dont know the length of it though.
Tip When you pull the injectors and if coolant comes into the holes stop there and install new injector cups but that takes a special tool.
Before putting in the new glow plugs once the new injectors are in crank the engine over for a few short periods letting the starter rest for a few min in between do not hook up the eletrical to the injectors to start out with.
There is a good write ups out there.
mgassel is offline
