Fuel Filter Cap
I am trying to change my Fuel Filter and can't get the cap off. This cap doesn't have the 1/2" Stock to turn the cap. I also have tried takeing a screw driver and slightly taping the tap the cap to get it loose. No Luck. Any Tips or Tricks on how to get this cap off?
might try to drain a little of the fuel, might be under pressure...
No Luck! Any other Thoughts?
Big channel locks. You're probably gonna have to replace the cap anyhow. If you don't buy the motor craft one, they usually all have a cap with the filter. You could also try to crack the top and break it. They aren't that hard to crack. I have cracked one of mine before.
Sent from my Acer Android Tablet |
I once had a 6.0l that i could not get the cap off ended up having to use a hammer and chisel to break it apart then split the plastic to remove it. Not the best way to do it but thats all i had for options
36mm socket on the end of it and it'll pop right off. Don't forget to pull the drain plug first.
I assume hes talking about the one in the engine compartment not the one on the frame rail.
My bad.. Try a strap wrench?
^^^ I wobble strap wrench worked perfectly when I had a fuel filter stuck in my 7.3 when I got it. Press down on the strap with your hand as your turn. Good luck!
You can also drive screw drivers into each side, cross them and where they cross grab them with channel locks and it will pop right off.
