Oil leak question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-08-2012, 05:48 PM Thread Starter
Oil leak question
Does anyone know, are can anyone tell me what that horizontal pipe looking thing on the drivers side of the motor is. It runs along side the block from front to back, on a 7.3 it seems that im getting an oil leak from there on I just can't tell what is is. Or what it does. Its just now starting to leak at 227k, and I can't handled an oil leak, its not a bad leak but it will leave a spot where I park where else, could it be leaking the valley seems dry.
D.N.S.
08 250 3" Lift
Diamond eye 4" Down-pipe back
No Limit Fab CAI
No Limit Fab. Egr Delete
35" nitto's
H&S Mini
RichardT is offline
post #2 of 7 Old 03-08-2012, 05:49 PM
Solid98's Avatar
Quoted: 8 Post(s)
Oil cooler.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #3 of 7 Old 03-08-2012, 07:23 PM
Freedombyforce's Avatar
Call Dieselorings.com. Tell Bob that the horizontal pipe looking thing on the drivers side of the motor is leaking. He will fix you up. You might want to do a few searches on "oil cooler leaks" first.
2002 F-250 CCSB
ZF-6 Swap
Manual T-Case Swap
K&N Intake, CCV Dumped, Riff Raff Boots
Foil Delete, AIH Delete, EBPV Delete
Wicked Wheel
Farm Boy's 5" Straight Pipe with 6" tip
PHP's Tunes with 6 pos
Hutched 51 gal Titan Tank
Iron Bull Bumper with PIAA 510's and Strobes
Warn M12000, Retrosolutions LED's inside and out
2011 Tailgate -Taillights - Front Ford Emblem
17" Fuel Octanes with ProComp Extreme AT 35's
Freedombyforce is offline
post #4 of 7 Old 03-11-2012, 06:39 AM Thread Starter
Ha ha, oil cooler, ahh how hard is it to change? Does look bad, , see learn something every day,
D.N.S.
08 250 3" Lift
No Limit Fab CAI
35" nitto's
H&S Mini
RichardT is offline
post #5 of 7 Old 03-11-2012, 12:14 PM
Solid98's Avatar
Quoted: 8 Post(s)
It's not that bad. You do have to drain all the oil and coolant. The only tricky part is pressing the manifolds back onto the pipe. They are sealed by large o-rings and I have read about people cracking the pipe or the manifold by applying too much pressure. You can get the reseal kit here :Replacement O-rings for Ford Diesel Engines
and if you do damage the pipe you can get another here :Riffraff Diesel: Ford 7.3L Oil Cooler 94.5-03
Mine only seems to leak in the winter so I'm holding off doing mine till it gets worse.
Guzzle has repair instructions on the above link.
Solid98 is offline
post #6 of 7 Old 03-11-2012, 08:15 PM
Jordan72's Avatar
Just did mine last week, mine only leaked when it was super cold out side and would only dribble when I first started the truck but it drove me crazy. Not to bad to do but just a pain to drain all the coolant and oil... Also the front bolts are kind of a pain to get to, you have to go through the wheel well but its still tough. Total of 4 o rings and 2 gaskets for around 70 bucks and id figure 2-4 hours of work if you haven't done it before. Any questions shoot me a pm or there are also some great write ups on the forums that will help with pictures.
Early 99' CCLB, 05 Harley Front End, 05 Harley Black Leather Interior, 05 Lighted Tow Mirrors, Built Trans
Jordan72 is offline
post #7 of 7 Old 03-12-2012, 06:07 AM Thread Starter
Thanks, As soon as i get my 6.4 08 out of the shop long enough to be able to clean it up and put it in my shop, I will get it done, Along with a few other items that i need/want to do to it, Theres no way i'm parting with it, Its my back up Vechile, Its been in the shop once FOR A RECALL, in 13 years, my 08 has been in the shop 3 times in 6 months, Every time i get ready to do work on it the 6.4 breaks down. I think i'll part with it. and keep my 99 7.3 I wonder how $$$$ for a new one?
D.N.S.
08 250 3" Lift
No Limit Fab CAI
35" nitto's
H&S Mini
RichardT is offline
