Safe EGT temps - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-08-2012, 03:33 PM Thread Starter
adavis11's Avatar
Safe EGT temps
I just installed my egt sensor on my early 99 7.3 and was wondering what is a safe temp to run at. I have a edge evolution set to stage 2 and am running around 700 to 800 degrees. If I really get on it, the temp jumps up to around 1075 but just for a few seconds while the pedal is to the floor, and then it is right back down to around 750 as soon as I let off.
2013 6.7 Powerstroke Platinum
adavis11 is offline
post #2 of 13 Old 03-08-2012, 03:50 PM
SuperCrutyPS's Avatar
Quoted: 322 Post(s)
Garage
General rule of thumb for EGTs is sustained up to 1200-1250*, bursts can go above that, but not for long. Sustaining above that, depending on how high you go, can start melting stuff.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 13 Old 03-08-2012, 04:30 PM Thread Starter
adavis11's Avatar
So if Im pulling a trailer and I am reaching a constant temp around 1150, is that ok, or am I flirting with disaster?
adavis11 is offline
post #4 of 13 Old 03-08-2012, 04:34 PM
Term3's Avatar
Quoted: 2 Post(s)
That's ok as long as your also maintaining proper coolant temperature and not overheating.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 13 Old 03-08-2012, 04:41 PM
zrain25's Avatar
At what speed do you see 700 I see 700 around the end of 3rd gear at like 43 around town the most I hit is 600 under normal driving
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #6 of 13 Old 03-08-2012, 04:51 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
As long as you installed the sensor in the bend of the manifolds, you can sustain 1150 or 1200 degrees towing or open running with no issues. On the high end, if you are upwards of 1400 or more, you better not be there for a long period of time. I have hit 1500 once and got freakin scared. A few seconds ( less than 10 I'd say) on 1400 and I'd say that's enough, you'd better back out.
In the mountains here in NC, on the interstate crusing at 70 I see 700.
If the sensor is mounted post Turbo, then that's the wrong place.
Sent from my Acer Android Tablet
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 13 Old 03-08-2012, 04:56 PM Thread Starter
adavis11's Avatar
I have not been able to try it out that much I just put in the egt sensor this morning and have only had it out a couple of times to try it. Most of my test driving today has consisted of putting the pedal to the floor ( I just installed my programmer ) so I need to drive it normal and see what the average is. And yes I installed the sensor in the driver side manifold just before the up pipe to the turbo.
adavis11 is offline
post #8 of 13 Old 03-08-2012, 05:00 PM
what could cause the EGT temp to go up all of a sudden ? Was staying around 400 to 500 range all last week and now running in the 500 to 600 range. Running Edge Evolution with Silverline exhaust.
cowboytrucker is offline
post #9 of 13 Old 03-08-2012, 08:11 PM
has the ambient temp changed?
bruce51d is offline
post #10 of 13 Old 03-09-2012, 04:22 AM
Everything else has stayed the same. The boost has gone up about 2 psi and does not sound the same out the exhaust.
