Running light fuse keeps popping? - Ford Powerstroke Diesel Forum
Old 03-03-2012, 07:53 AM
The other day the 15 amp fuse blew for my running lights. Put in another and pop! It was dark and I had to have lights so I put in a 30 amp. Its still holding but I dont like it. Also when I arm or unarm my alarm the running lights dont flash anymore even with the 30 amp in there. I know electrical is hard stuff to trouble shoot, just looking for any ideas. Thanks!
Old 03-03-2012, 08:25 AM
Feedback Score: 5 reviews
For starters.... check the manual and put in the correct size fuse. You are risking frying your electrical by putting in a larger fuse. Double-check the manual, and report back what fuse it is, and what it goes to.
Old 03-03-2012, 10:24 AM
Says in the post the original was a 15amp. Put the 30 in to drive home and havnt drove at night since.
Old 03-03-2012, 02:35 PM
Did you tap into your running lights to do some of your recon light mods or mirror lights behind the on off switch for your lights? (if you have those). I used my running lights to light my mirrors up so i was just wondering. maybe that could be drawing the extra amperes
Old 03-03-2012, 02:42 PM
I did before when I had mechanical gauges. I will pull it off and look at it tomorrow. The Recon "BigRig" side bar lights tie into my blinkers up front. I am tearing the whole front end off tomorrow and getting rid of them crap connecters they come with and soldering and shrink wraping everything. To top that off I ordered some LED front blinkers and after I installed them, I hit the blinker and ALL the lights on my truck flash. Not related to this problem though I would think. Blinkers work fine with standered bulbs.
