Bully dog tuner
A truck accessories shop wanted to sell me a Bully Dog tuner, so I allow them to temporarily tune my truck and it worked well. If I decide not to but the Bully Dog unit, will I have to go to a Ford Dealer the get the codes reset before I can use another type of tuner?
Thanks Billyj |
If it was the try before you buy, then you should be ok because it will revert back to stock after a certain amount of driving time.
It will NOT revert to stock. It works like this.
You have stock. Then the dog takes the stock tune, copies it, puts the dog tube as the BASE tune on the pcm, then puts stock on top of it. So the dog is always running, but uses stock parameters once it "runs out." Reset the pcm and you'll still have the tune there. It's a flash tune, like an sct. My Samsung SGH-I997 made me send this. |
the bully dog doesn't copy the stock tune. it has it's own version of the stock tune in it.
don't run the bully dog on your 7.3. Just get a 6 position chip and be done with it |
it absolutely will not go back to true stock. I have put triple dogs on a LOT of 7.3's. I will sell them to guys with 7.3's and load them on their trucks, but I ALWAYS recommend a physical chip.
If they insist? It's their money and their truck, but I wouldn't recommend it. |
Then I shouldn't have go to a ford dealer for anything, just install the chip and go, Right?
correct. don't let them load the temporary bully dog tune. it may be temporary power, but it is NOT a temporary reflash!!!!!!!!
buy a 6 position chip with some good tunes on it, install the chip, and enjoy. |
the thing is, it's not even their version of stock... it's similar to the triple dog adjustable file but instead of four power levels, it has two power levels and once you hit a certain number of key cycles, it goes to the stock power level.
if you load a triple dog on a 7.3 or 6.0 and disconnect the batteries, it will revert to the stock power LEVEL the other stuff is still loaded on the ECM it isn't back to "stock" until you actually reprogram the truck back to stock and it can cause problems blocking other tuners, etc. if you REALLY want a triple dog, I'll sell you one for $240. If you're anywhere near Alvin, TX I'll let you try it out before you buy. but, I would recommend a 6 position chip |
