Help with boost gauge - Ford Powerstroke Diesel Forum
Old 02-29-2012, 12:06 PM
Gauges came in and i was trying to install today, but what i thought would be the easiest one to install, is the biggest pain in the butt! Ive tapped my boost gauge into several different vacuum lines, and still im getting nothing. Can someone take a pic of where they tapped theirs in please?!?!?!
Im done with it for the day, but will be back at it tomorrow!
Old 02-29-2012, 02:44 PM
i have my aih deleted with the boost line runnin to that. you can go down and get a cummins drain plug, that is supposed to fit the aih hole.
Old 02-29-2012, 04:44 PM
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I plugged mine into the boost line that goes to the computer. It crosses over the intercooler line to the passanger side. Ill take a picture tomorrow when there is light to show you
Old 02-29-2012, 04:46 PM
x2 from bruce51, just delete your AIH and tap into that, the best place for it. Somewhere online they sell a plug with a port in it to install a fitting for a boost line. Good luck!!!
Old 02-29-2012, 08:42 PM
Clean and simple.. mine is tapped for a sensor, but it sounds like you have a mechanical gauge, so here is the link for the mechanical fitting..
Riffraff Diesel: RDP AIH Delete/ Mechanical Boost Line
Old 03-01-2012, 05:49 AM
Thanks a lot guys! Im going back out to start on it again now! I know people do things different, so if there are any more suggestions let me know!
