what size centering pin?
is the centering pin in the front leafs 7/16?
yup sure is... doing an add-a-leaf? I had to replace mine when I did...
putting a block in to level the front
Eh, I'd advise against a block in the front. Never done one like that, but I've heard it's not the best/safest way to go...
I also advise against a block... not legel in some states, and unsafe in all... I don't even care for the 'mini-pack' type leving kits, even if they use a center bolt to hold it all together... I used a main leaf out of a spare set of stock springs with the ends/bushings cut off, leveled the truck nice... also needed to lenthen the track bar about half an inch with the added hight.
did the extra leaf make the suspension stiffer?
not noticiably... it's a truck, right? *grin*
would one leaf added to the front be enough to level the truck? i do have one kicking around. my truck is 3" low in the front.
There is NO absolute rule. It's a truck to truck basis. The heavier springs will take less....but then you have to account for how worn the springs are. I have 4,800# spring on the front, and they are just flat. The truck sits about 3-3.5" lower in the front. If I had 5,600# or 6,000# springs on the front... probably would be more like 1.5-2". |
so what if i just add one to the pack i have in there already?
