gauge required - Ford Powerstroke Diesel Forum
Old 02-25-2012, 10:37 PM
gauge required
Just rebuilt my trans on my 01 powerstroke, I know I need a transmission guage what other things should I monitor. My truck is not chiped and have no intention of doing so. Do I need to monitor the fuel pressure between the pum and injector pump. I ask this because my brother owns a dodge his pump whet out and was not aware and ended up having to replace both pumps
Old 02-25-2012, 10:52 PM
EGTs and boost. Then fuel if you want.
Old 02-26-2012, 06:32 AM
you have no injection pump (high press fuel pump), just a fuel transfer (lift) pump that fills the bowl and pressurizes it to 40-60psi.
i personally like knowing that i have plenty of pre-injector pressure, but mpst people dont give it a second glance until their pump takes a dump.
Old 02-26-2012, 07:16 AM
If you don't plan on chipping I wouldn't worry about boost. But I'd still check for boost leaks anyway. Then trans temp, EGT, and fuel pressure and maybe coolant temp.
