under dash fuse box removal - Ford Powerstroke Diesel Forum
Old 02-25-2012, 01:32 PM
does anyone know where i can find instructions on how to remove the fuse box under the dash?
Old 02-25-2012, 03:01 PM
I had to remove mine when I did my headlight mods. IIRC, there's 4 10 mm screws holding it on. Could be a few more? From there its just pulling the plugs off the back and pulling it out. There's one that has like a horseshoe like connector on it. Unlock the sliding tab and pull it off.
Believe that's about it. Might wanna disconnect your batteries too.
Sent from my DROIDX using AutoGuide.com App
Old 02-25-2012, 03:44 PM
ya i took the screws out. i had trouble figuring out how to get the plugs out of the back. not sure what the horseshoe tab is
Old 02-25-2012, 04:01 PM
On the back when your peeking over the top it'll be on the right hand side. Has like a pull ring on the end. Give it a little tug and it should slide open. From there its simply pulling the plug.
Old 02-25-2012, 04:44 PM
ok cool ill check in the morning. i notice there are two 10 mm screws on the back of the box also do i need to take those out?
Old 02-25-2012, 05:35 PM
I don't believe so unless your trying to take the fuse box completely apart.
Old 03-07-2012, 06:40 PM
Ya there were 2 screw on the back I had to take out. I see you have an 03 cody. 03's have a different and larger fuse box under the dash because they took the one out from underneath the hood. that's why i was having a hard time following your instructions but thanks. I did finally get it out today though which is good.
Old 03-07-2012, 07:55 PM
Hmm didn't know that.. plus I didn't take mine completely out, I just had to move it enough to splice into a wire.. but it was hanging down. Glad you got it done, and sorry for the confusion. Lol
Old 03-09-2012, 07:25 PM
Put a new fuse box in today. fixed all my problems! worth the $350!
