Block heater - Ford Powerstroke Diesel Forum
Old 02-23-2012, 03:45 AM
Block heater
Is there anyway to check for a short on the block heater? Im putting a new plug on it this weekend. 2000 F350 249k miles
Sent from my C771 using Tapatalk
Old 02-23-2012, 05:22 AM
You can ohm it out by putting the test probes on the plug....I can't remember the correct ohm's it should read but there is a article somewhere here about testing the heater.....Fred
Old 02-23-2012, 05:26 AM
Ok I found it....it should ohm out at 14-16 ohm's using a probe on each of the flat plug prongs at the same time.....Fred
