Am I going to melt something important? - Ford Powerstroke Diesel Forum
Old 02-23-2012, 03:04 AM
I installed new ISSPRO gauges to replace the glowshift gauges that were in my truck when I bought it. Yesterday while towing my boat I noticed my EGTs were at the redline (1200+) while pulling a hill. How long can I hold this temp before bad things start to happen? I haven't pulled my 5th wheel camper yet, but at 9000lbs that's got to be a whole lot worse. I should mention that this truck has stage 2 injectors in it. Maybe that's what is causing the high EGT? Or maybe the chip itself? Can anyone give me some advice? Thanks
Old 02-23-2012, 04:19 AM
1250 and higher than that, and you're risking melting something the longer and higher you go from there.
Old 02-23-2012, 05:15 AM
is the EGT temp probe in the manifold BEFORE the turbo, or in the downpipe AFTER the turbo?
if BEFORE, not good... If AFTER... HOLY crap thats hot
Old 02-23-2012, 05:23 AM
EGT probe is in exhaust manifold before the turbo
Old 02-23-2012, 05:27 AM
well let me ask a few questions.
what intake setup are you running?
what exhaust setup are you running?
stock/aftermarket downpipe?
gutted EBPV?
standard or automatic trans?
Old 02-23-2012, 05:29 AM
Does the chip have a tow setting on it?
Old 02-23-2012, 06:06 AM
S&B intake
4" turbo back exhaust w/muffler
wicked wheel
chip is stock, high idle, 40hp tow, 60hp tow, 80hp tow, 80hp street perf.
Auto trans.
stage 2 injectors
everything else is stock
This isn't sounding to good for me
Old 02-23-2012, 06:11 AM
S&B intake
OK, not bad
GOOD!
wicked wheel
shouldnt affect anything except surge
what setting was it on when this happened?
Auto trans.
hmm...
stage 2 injectors
This "could" be part of the problem...
it could be something as simple as your PYRO sending unit/gauge is malfunctioning... I just dont see a reason why your EGT's would be that high with such a small load
Old 02-23-2012, 06:18 AM
Originally Posted by the trav View Post
S&B intake
OK, not bad
GOOD!
wicked wheel
Auto trans.
hmm...
stage 2 injectors
I was running in the 60hp tow. I usually run in the 80hp tow. But it blows to much black smoke for me.
The injectors wouldn't surprise me. The truck runs like crap about the first couple of minutes when it is started.
Old 02-23-2012, 06:36 AM
Feedback Score: 5 reviews
So you don't have a turbo to support those injectors and give enough fuel.
I think you are overfueling with large injectors and dont have enough air...
Bigger turbo....
