what headlights fit? - Ford Powerstroke Diesel Forum
Old 02-21-2012, 02:13 PM
Im from over in the older truck section, but my buddy has an 2000 ford f250xl. So it has the one piece sealed headlights. hes wanting to put in hids. what year headlights will bolt right in, thanks
Old 02-21-2012, 02:16 PM
According to what I have been told 99-07 headlights all bolt up the same. Even the guy at the dealership said they all should bolt right up. Even the grill
Old 02-21-2012, 03:38 PM
99-04 are the same 05-07 are a little different. You have to trim the header panel or put a newer header panel on for the 05-07 lights to fit
Old 02-21-2012, 04:30 PM
No they don't. 05-07 are different. Headlights need a minor modification.
The grills need quite a bit cut off the bottom to fit. I have a modified one.
Old 02-21-2012, 05:24 PM
Do u have some pictures of where you had to trim for the headlights? Cuz I want tout those on my 04 as well
Old 02-21-2012, 05:45 PM
Peep this thread....
05-07 CONVERSION instructions. ( here )
Old 02-21-2012, 05:49 PM
Thanks I will probably put some on next month when I have some extra cash I just bought the sct live wire tuner and I'm about to order a lift
Old 02-22-2012, 09:05 AM
Are the 2003 lights a 1 piece? (side marker and turn signal with headlight)....I also want to update the look of my 2000, Thanks, Fred
Old 02-22-2012, 11:35 AM
no only the 05-07 the 03-04 look a little different than 99-03
