How do I install a track bar on a f250 Dana 60 conversion? - Ford Powerstroke Diesel Forum
Old 02-12-2012, 06:10 AM
I am buying a Dana 60 for my worn out f250 front end. How do I put on the track bar? Can I bolt it? Weld it? That's the only process I am confused about? We're do I buy one? Thanks Everyone?
Old 02-12-2012, 09:27 PM
Are you getting the axle from under another Super Duty truck? The leaf spring pads on those are large (especially the cast driver side...) If your getting it from another SD (I'd recommend that), the track bar should bolt right up, the axle mount is on the right side.
If your looking for a 60 from under a super duty, go after a 1 ton dually...
Old 02-12-2012, 09:29 PM
spool up that turbo!!
I think he meant to post in the obs section
