Greentuck: If possible next time you change the F/Filter... Take a pic of inside the bowl and post it... Most important thing to me is you don't want to send that crud to your injectors... You might spend some time and try to remove as much as possible... via a slow process as a hand full of q-tips or small wipes....
Or even try to suck it out some how... Then something to think about is to open the water separator {Yellow Lever} on the back of fuel bowl... and Leave it open... Place a large bucket under the drain tube... Then flush the bowl with fresh diesel a few times... maybe to flush any small pieces of that crud out of there... Maybe even spray out a few times with carb cleaner then flush with fresh diesel... Just make sure the yellow lever is in the open position so all will drain ...
This might take some time... This might even be a bad idea... The only thing to me is you don't want that crap going into your injectors...
After this problem is solved... Change that filter between 10K-15K miles... No matter what...
Also try to by your fuel from the busiest truck stop or quick stop {Thats sells alot of Diesel}... That way you know you are at least not pumping 3month or 6month old standing diesel into your tank...
Maybe other owners will give their thoughts or opinions on this matter... I have never had this problem... I just threw out a few ideas...
Reason: Hush Your Mouth!!!
