HIGH Cruising Boost - Ford Powerstroke Diesel Forum
Old 02-09-2012, 04:31 AM
HIGH Cruising Boost
Going 70MPH, level ground, wind 5MPH or less, shouldn't I get around 4PSI boost or something close? Basically little to nothing right?
I get 9-10PSI.
Yea, I know I have more rolling resistance since it's a dually, more weight with the fuel tank, tool box and stuff in the box, but I didn't think it'd make that much of a difference.
Old 02-09-2012, 04:54 AM
Mine isn't a dually but running like you mentioned, full of fuel, estimated 500 lbs in back with tool box and goodies i see around 5psi. I don't see numbers like you're seeing unless I have a trailer.
Old 02-09-2012, 07:57 AM
Faulty gauge? Has it always done this or did it start recently? Any change in MPG? (If it started recently) I think you would have noticed, but are the brakes dragging? I'm even not sure if that would cause enough resistance to double the boost.
Old 02-09-2012, 08:10 AM
Do you have 4.10s in your truck? That's probably why. I'm sure us srw guys with 3.73s are at the same boost numbers at that rpm.
Old 02-09-2012, 09:28 AM
Gauge works great. 4.10s, yes since it's a dually. That means at 70 I'm running about 2200RPM. At 55 it's about 17-1800RPM and that's where I get my 2-3PSI. But 2050RPM and above, that sucker really is lit up. I LOVE it
Old 02-09-2012, 09:47 AM
I'd say thats about normal then. I'm at 6 psi at 2000 RPM/76-77 MPH with my 35s.
Old 02-09-2012, 12:10 PM
I have a dually, 4:10s and run about 9 inches of boost @70, 10 inches if I'm buckin a headwind.
Old 02-09-2012, 02:23 PM
Ok cool. I knew it wasn't over boosting just didn't realize it would go that high just cruising
