FL ppl oil question. - Ford Powerstroke Diesel Forum
Old 02-08-2012, 04:53 PM
Are you all seeing much difference using a synthetic oil vs a conventional oil? I am debating on switching from 15w40 to 5w40.
Old 02-09-2012, 10:26 AM
SyN SyN is offline
Lubrication Addict
Nuthin: Problem is this has been and is always being talked about in every diesel pickup forum...
Looking and seeing that U live in Florida... Where the weather is really ideal most of the time... Hardly ever below freezing or Extreme Cold... Which this is where the 5W-40 really shines compared to the very thick 15W-40...
The only true advantage that the 5W-40 synthetic oil is during cold start ups... This Oils pump ability is far superior to the 15W-40... You want that oil getting up to the top of the motor ASAP... Hence the 5W pumps way easier then the 15W... We have been told for many yrs that most engine wear occurs at start-up...
I myself left a qt of 15W-40 out side one night when the temp dropped down to 13*F... The next morning I tryed to pour that full qt into an empty gallon jug... ROFL... It took at least 5min for at least 1/2 the full qt to pour out.... Though not a scientific test? It doesn't have to be for me to see, the 15W-40 was never going back into my 7.3L...
I didn't know how sluggish and poor my throttle response was until I switched to 5W-40... What a difference it made... I now mainly pour in T5 10W-30 yr round... My 7.3L really reacts differently compared to the thick 15W-40...
I'm running a mix now {This Winter} because WM only had 2 gallons of T5 so I had to substitute 2 gallons of T6 5W-40... 4gallons total with the ELF7405 Filter...
I will tell you this... if your wallet will not be hurt by the extra cost of the 5W-40? Try it... I'll bet you will not go back to 15W-40... The extra cost is the only draw back... You might be able to extend your OCI to 7K-8K miles to justify the extra cost...
Good Luck in your Quest...
This question will stir up many many different opinions... This is just mine... Nothing More.
It's your hard earned money... Many 7.3L owners are making the switch to 5W-40 or HDEO 10W-30 and wondering after the switch why didn't I do this yrs ago...
But with all that said... With You living in a Warm Climate most of the yr... 15W-40 will serve your PSD very well....It's all about wanting to try something new!
Take a look see around this area... alot of good interesting opinions here...
http://www.bobistheoilguy.com/forums...oard=22&page=1
Old 02-09-2012, 04:08 PM
Send a message via AIM to rufushusky
In my experience you won't see much of a difference. I only notice a difference in throttle response when cold, once the engine is warm a 15w-40, a 5w-40 and a 10w-30 all feel the same to me. I know other will object but IMHO, in your climate you won't notice a difference.
Old 02-10-2012, 04:01 AM
Yes you will notice more attributes of the synthetic oil in colder weather. The big difference in synthetic oils is that they are better lubricants. Thus better for your engine. I'm a bit anal and use synthetic oils on everything, its worth the extra cost to me.
