Fly Wheel Problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-08-2012, 03:14 PM Thread Starter
duct tape & zip ties
bigcountrysg's Avatar
Fly Wheel Problem
Ok so how many of you with an Automatic behind a 7.3L Powerstroke have had problems with your fly wheel.
I am asking because my friend's broke into two pieces, the center where the bolts go to the fly wheel seperated from the rest of it. He has about 150,000 miles on his truck.
Now my truck is making the same noise and I am preparing to remove the transmission to see what is going on. I already bought a new fly wheel. I have 239,000 on mine.
My buddy was told that when the fly wheels were made for the 99-2002 trucks. They were over heated and that actually ruined the heat tempering of the steel. So the metal is weakened.
I am trying to find out how many have had problems with this.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #2 of 7 Old 02-08-2012, 06:19 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Whats the sound like?
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 7 Old 02-09-2012, 03:53 PM Thread Starter
Metal on metal grinding noise, it goes away around 1,000 rpms and comes back when the engine comes back to idle.
My buddy's fly wheel was in two pieces when he took it apart.
2002 7.3L burnt
post #4 of 7 Old 02-09-2012, 04:07 PM
Powerstroke Techie
justinmix's Avatar
I think you mean the flexplate, not a flywheel right? An automatic trans uses a rather thin flexplate, unlike a heavier, thicker flywheel in a manual truck.
I've ran into cracked flexplates rather often. It's not a super common failure but it does happen. It will normally make a horrible rattling sound until you get over 1000 rpm, and will usually only make the noise when not under load. You can also have the same sound if you have an issue with your torque convertor.
The flexplate will crack right outside of where it bolts to the crankshaft. I'm not sure what exactly causes this.
I would say replace the flexplate and let it eat. You'll be fine.
If you have a manual trans and are hearing this noise then it's probably caused by a faulty dual mass flywheel, but if I remember right I thought they were only used in the OBS trucks.
justinmix is offline
post #5 of 7 Old 02-09-2012, 04:12 PM
Powerstroke Techie
justinmix's Avatar
Never mind, I just looked at your profile and see you have an automatic. You have either a goofed up flexplate, or a torque convertor issue. More then likely you have a flexplate problem.
BTW, you have a 4r100 trans, not a e40d. Not a huge difference from a e40d besides a couple other speed sensors.
post #6 of 7 Old 02-09-2012, 09:20 PM
Zaairman's Avatar
Quoted: 12 Post(s)
My truck makes the rattling sound at idle in park. I've just always assumed it was the torque converter.
Zach
SLAPS Member #153
Zaairman is offline
post #7 of 7 Old 02-10-2012, 07:20 PM Thread Starter
flexplate is what it is. I have always called them flywheels, because in the Marines when you look you up a flexplate for a hummer it is listed as a flywheel in the parts manual.
It was cracked all the way around where it bolts to the crank. My buddy's did the samething this week too.
2002 7.3L burnt
