Charge/battery dash light flickering on and off
During these cold mornings like these (about -2), after first starting, my truck must have a bunch of vibrations because the charging system warning light on the dash starts flickering on and off.. I plan on checking wires leading to the alternator and battery for tightness, but is there anything else I should check for? Any other wires leading to some where that could cause this? The light goes away usually when I put the truck in drive and it warms up a bit.
Thanks! Last edited by thebierguy; 02-09-2012 at 04:26 AM. |
Could a bad alternator or bad battery be causing this light to be turning on and off within 5-10 seconds?
This morning, on the way to work, everything was warmed up, and that light turned on for about 5 seconds, turned off for 2 seconds, flickered a couple times, and then stayed off for the rest of the trip. Total trip is about 24 miles. I opened the the hood to have a look and it didn't seem that any connections were loose on the batteries or alternator, but I will stick a wrench to them this afternoon. |
id have your alt and batteries tested, its free
