Trailer wireing connector replacement - Ford Powerstroke Diesel Forum
Old 02-02-2012, 03:54 PM
The guy before me cut the connectors off of the trailer wires, I just have the trailer wires stripped at the ends. Is there a replacement plug. Or will I have to hard wire it
Old 02-02-2012, 05:37 PM
The way you make it sound is....You have a trailer with the connector cut off. Go get a connector that will matches your truck, Walmart, Kmart or a auto parts store. Wire it to your trailer wires and you are good to go.
Its so easy a caveman can do it.
Old 02-02-2012, 05:41 PM
No the truck side. The actual truck connector is cut off. There are no connectors what do ever just wires
Old 02-02-2012, 05:48 PM
Ford does have a replacement plug. I don't have the part number off hand but if you need it I can get it for you later when I get home.
Old 02-02-2012, 05:53 PM
Yea please that would help
Old 02-02-2012, 05:55 PM
I'll post it in a few.
Old 02-02-2012, 07:52 PM
Here is the part numbers. This is what your looking for correct? Sorry for the crappy pics.
Old 02-02-2012, 08:12 PM
can be bought at any farm store or truck repair shop. Nothing speacial that you need a "Ford" one.
Old 02-02-2012, 08:15 PM
The picture i posted above is the one that plugs into the back of this one. It's the pigtail.
It plugs into the back of this one.
I replaced that one With the new style. here is the new one
And part number
Old 02-04-2012, 03:26 PM
Not sure if the post or lice above answered your questions but I just got done reeling mine cause it was all corroded and it sounds like the guy cut the wires before the factory female end. If I was you I would go to a scrap yard and get a female plug then use butt connecters to make it factory basically and then buy the male end to a seven pin connector or whatever you need.
