2003 F250 7.3...... Alternator - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-01-2012, 07:36 PM Thread Starter
rwtdct's Avatar
I the last 5 years I have put 4 alternators on my truck. Original alt. lasted 5 or 6 years then went bad. I replaced it with a Kragen brand, it went bad with-in a couple months. Someone mentioned stay away from them. So I got a NAPA alt. and it went bad with-in a few months. NAPA suggested to put a motorcraft alt on, so I did threw NAPA. The motorcraft alt. lasted 2 months shy of two years. Good thing it had a two year warr. I replaced it with another Motorcraft alt. The alt. is charging but the battery light is still on.
Yes the wires are installed right.
Someone mentioned these year alt's. have problems with the built in regulator?
Could someone tell me what is going on? Why do I keep loosing alt's.? Why is my alt. charging and light still on.
His....2003 Ford F250 7.3
Hers....2006 Ford F250 6.0
rwtdct is offline
post #2 of 16 Old 02-01-2012, 07:42 PM
duct tape & zip ties
bigcountrysg's Avatar
How Old are the batteries? You have replaced the alternator but you state nothing about the batteries being checked or replaced. Also did those places even bother bench testing the alternators or just warranty them out? Put the batteries on a trickle charge for a few hours each. That means pull the batteries out, hook them to a battery charger one at a time. Put the battery charger on 12volts at 15amps for about 4 hours. Then check the voltage and amperage of each battery. If the amperage is not near the battery rating. Most likely you have found your problem.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 16 Old 02-01-2012, 08:11 PM Thread Starter
rwtdct's Avatar
The alternators were working for a few months, when I noticed the battery light come on I checked it with my volt meter to see if it was working. The alternator I have now shows it charging but the battery light is still on. I have had this alt. on sence Aug. The light hase been on every sence. So far as the batteries, My truck starts up normal as if the batteries were fully charged. I guess I could or should have them load tested.
rwtdct is offline
post #4 of 16 Old 02-02-2012, 12:43 AM
dentexpowerstroke's Avatar
x2 on checking the batteries. I have seen a ton of people replace alternators when it's really a bad battery. I can't believe no one at the parts store told you to do that.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #5 of 16 Old 02-02-2012, 07:59 AM
Yepp, when you have two batteries hooked in series. You can have a bad battery and the other will work harder. But you would never know you have a bad battery until they are dead.
2002 7.3L burnt
post #6 of 16 Old 02-02-2012, 10:51 AM Thread Starter
rwtdct's Avatar
I will check the batteries and let everyone know.
rwtdct is offline
post #7 of 16 Old 02-02-2012, 06:21 PM Thread Starter
rwtdct's Avatar
And I have seen a lot of people buy batteries when it was the alternator.
The alternators that I replaced were definitely bad.
The first thing I check when I have a battery go dead is the alternator.
Anyways, I disconnected both batteries to see how many volts were in each, both 12 volts.
Next step...Load test each battery
I will let everyone know the outcome as soon as I do it. It might be a couple days. I live out in the country and sometimes work long days. So I will do it when I can.
rwtdct is offline
post #8 of 16 Old 02-02-2012, 06:41 PM
DrewGerhan's Avatar
Not to split hairs, but our batteries are wired in parallel.
E99 7.3L ECLB 4x4
140,000 miles
4" lift on 33s
6637 Filter
5" Diamond Eye
PHP Phoenix
Quad Gauge Pod
05-07 Headlights
DDM 55w 10,000K HIDs
Harpooned
800w Pioneer amp and 10" Kicker sub
Avital 5303 Remote Start and Alarm
DrewGerhan is offline
post #9 of 16 Old 02-02-2012, 09:42 PM
Basically what everyone is telling you is your battieries could be bad and it can kill the alt too because it is over working itself.
mgassel is offline
post #10 of 16 Old 02-04-2012, 07:21 PM Thread Starter
rwtdct's Avatar
Ok.....I went and had my batteries tested, both were fine. One the cranking amps were a little lower than the other. (old batteries were dated 05/06).
So I decided to replace them both anyways. (new ones dated 01/12)
Battery light is still on.
With the truck running (old and new batteries) the alt. is putting out 14.2 volts (seems a little high). The two wires coming out of the back of the alternator connector is at 12.2 volts running or turned off.
I am thinking replace the alternator.....anymore suggestions.
rwtdct is offline
