new ball joints now it feels weird
Yesterday I took the truck to a well known suspension shop to install my ball joints and they also put in a new tie rod end and a steering stabilizer. When I picked up the truck it was wondering around and it took much more turning to get the truck to react. I can drive down the freeway at 70 mph and wiggle the wheel back and forth and it will not turn right away. Its like there is a TON of play in the steering. I took it back today and they said everything looks right and that what I am feeling is the ball joints breaking in and it should get better as they break in and work themselves out. The guy claimed that as the grease works its way into the new ball joints this will go away.
REALLY?!?! could this be true? |
I've never heard of that...everytime i've done ball joints and tie rod ends i've always felt the tightness in the steering/suspension right away.
That is what I thought also. I think they are just giving me the run around. This is why I usually don't let anyone work on my stuff.
Have someone turn the wheel back and forth while you look under it. Sounds like it's play in the gear but you want to pin point exactly where it's coming from. They just did one tie rod end?
The only tierod they did was the one on the pitman arm. Ill check this evening when I pick it up.
Did they/You do anything with the end links on the sway bar or the sway bar bushings? If not energy suspensions sells a kit that is great, they are easy to do also. If all of your components in the front end are "good" and you still have play you may want to adjust your steering box... on top of the box is a 5/8 diameter nut, youll also need an allen wrench for the screw on top. Back the 5/8 nut off a 1/4 turn and adjust your allen screw clockwise 1/8 to 1/4 turn(s) at a time so as not to overtighten, test drive and you will notice an improvement.
Key here is 1/4 turns on the allen screw and test drive and re-adjust if necessary...it may take a couple of shots at it but it will help you out. |
Check the nut holding your pitman arm to the steering stabilizer. If its loose, than that will cause play in your steering wheel.. hope you get it figured out soon.
I looked under the truck with my helper turning the wheel and the only play I can see is in the steering box. I bought a red head box that I will install this weekend and hopefully that will fix my issue. All I can think is that now that the slop in the ball joints and steering link is gone it amplified how bad the steering box is. The truck now has 236k miles. Its about time for a steering box anyway.... Ill update this thread after I put in the red head box. Fingers crossed!!!
Oh and I already adjusted the box as far as I am comfortable going. I adjusted it 50k miles ago to help bandaid the slop I had. |
